Hi
Picking up a 2006 1.2 Panda next week. 89000 miles and I will change the oil and filter I probably use a Fiat filter but am unsure about whether to use semi or fully synthetic oil. What do people use?
Use cheaper semi and change it more often, expensive oil is really not necessary in most cars and its just a marketing gimmick.
Thanks for the replies. I think I'll get a semi such as Magnatec 10w40 with a Fiat filter and change every 6000ish. That is if I can get under the car without jacking it up as our driveway slopes. If not I'll get the garage to do it and supply the filter and maybe the oil too.
You should just be able to get under it on the ground, I do out of stubbornness of not being bothered to get it into the air
And don't trust a simple jack alone....use some extra stands or something to secure the car when it's up..
... Or use a syphon pump made for the job.
Some will cry out in horror when they hear this, but I have been using such a pump for many years, and have saved all the hassle of hot oil on my hands, crawling about underneath, etc.
I get the engine hot, pump the oil out through the dipstick tube, fit new filter, and pour in new oil.
Ten minutes, clean and easy. No I'll-effects on engine.
Have several high-mileage cars, still running beautifully.
Doubts? Ask the Americans - they've been using this method for years.
Sweetsixteen.
