Hi! I bought a fiat panda 100hp two days ago and finally took it for a drive today.
However I have had a concerning issue with the gears/clutch. First I couldnt select any gear, the stick just wouldnt slot in anywhere, then when it worked again after restarting the engine, it worked. Five minutes later I stopped in 1st and tried to select neutral but it wouldnt budge! It was now stuck in 1st, this was resolved by using a little force but then (again) couldnt select any gear. Then I noticed my clutch pedal hadnt sprung back up so pulled it up and everything worked fine again!
What do you think the problem could be? Are there any guides to check the slave cylinder? (I dont know my way around cars yet, this is my first one)
