Hello,
I have Panda 2011 69hp and I have fatal problems with headlights!
Normal headlights wont turn on (dipped beam). I think switch work ok, because I hear clicking sound and backlights turns on normal, but normal headlights just says nothing. Main beam (or what is it?) works too.
I have investigated problem long night and voltage comes good to 7.5amp fuses on fuse box (0v when lights off and 12v when switch is on). Lights height adjustment works fine and its from same fuse as the passanger light.
Voltage even comes to headlight, but very weak: There is about 10volts when the bulb is not connected and when I connect -> voltage disappears.
I wired voltage straigh from battery and both main beam and dipped beam worked good (I dont know right words). I replaced the bulbs just for sure.
Nothing comes to my mind. The voltage just drops somewhere between 7.5amp fuses and bulbs. Because both lighs are off, there must be one bad connector or something?
This is very weird because I had similar problem with -99 Fiat Bravo, but the passanger headlight worked fine. (10 volts when bulb not connected and disappears when connect) and I didnt found any solutions. I just wired from passanger headlight to drivers side headlight and all worked fine many years.
But Panda lost both lights at same time?!
Please help!
Please help!
