Hi folks,
My friend bought a panda after I told him how reliable and cheap to run they are, sadly within a month he was sat at the side of the road with the car not moving.
I came and picked him up and the car would just about move if given a load of throttle but topped out at about 5mph, the gear selector worked fine and the engine was revving freely which all points to the clutch.
The car is on 80,000 miles so was probably due one but I don't want to start removing the gearbox and find it was a clutch cylinder or something similarly easy to replace.
I am a competent DIY mechanic and have changed the gearbox and clutch on my mx5 before, something I assume was probably a lot more difficult than the pandas would be?
Is there anything else I can test before removing the box? And if it does come to removing the box how tricky a job is it and what will be needed, I will replace the gearbox fluid,clutch disk, plate and release bearing, is anything else worth doing whilst I am in there?
Cheers!
Cheers!
