So, before the thread degenerates into the usual twaddle, can we have some opinion on ECU scanners?
1. Android has one called 'Torque' though I'm not sure if it's for Yankee motors.
2. I think our best choice if
MultiECUscan. Can you gimme the link?
3. The advantage of Android ones is that you can get them to work (clunkily) with Bluetooth and your Android devise, thus saving you the effort of plugging in the laptop.
4. Ideally something that would also work on a SEAT.........
Ta.
It all depends what exactly you want to do. If all you want to do is reset a Mil light and read an error code - then you can buy a handheld unit for about 10 quid from fleabay.
If you want to look at some parameters on the screen - like temperatures, rpm - and basic stuff - torque is great. (but **** slow)
If you want to a proper diagnostic and analysis tool and test tool for the Fiat, Alfa and Lancia range, then
MES is the only option really.
You need an OBD adapter , either bluetooth (not reccommended for any adjustments !!) or USB. torque very basic and generic really, a good program, but not a real tool as such .. it support bt.
MES support BT and USB. BT is NOT reccommended for any adjustments as said, UNLESS you use cantiecar interface.
Also, torque only connects to basic can output - it cannot address individual ecus, neither can the cheap hand held units,
MES can and does address ALL the ecus in the vehicle - you have MANY... to speak to and look at them all, you need a set of adapter leads to go on the end of your OBD adapter !
The adapter is usually ELM327 based or VAG COM, ELM 327 is more widely used on our motors.. even then, you wont be able to address the airbag ecu without VAGCOM as well. so you owuld need two interfaces and a set of leads.. AND -
MES.. or, there are interfaces such as OBDKEY that allow full connection - with adapter leads - it IS possible to damage the vehicle connector with the wrong lead on certain models - beware ! - usually just a fuse - but !...
Best option, by far, is the multiplex version of
MES with CanTieCar interface, this is a multimode interface that is controlled from the
MES software - plug and play - no leads or adapters to change.
Again if all you want to do is read a basic error code and turn the light off - then a 10 quid handheld unit off ebay will do that. but it will not, for example, allow you to fault find - say - throttle pot, lighting circuits, steering system - and eveything else that is accesible to the program (
MES) - torque doesnt do ANY of that.. and no, it doesnt (
MES) support SEAT.
It does, as said above, support two suzuki units only - an SX4 1.9 and 2.0 DDIS - whatever they are
Anyone with a modicum of understanding of the systems and a desire to know what is happening on their own vehicle should have
MES registered IMHO.
Fist time you need it, it will pay for itself.. use it every month or so to check the system .
Anyone thinking of buying a fiat / alfa / lancia should take the
MES system with them when viewing also.. again, it will MORE than pay for itself as you can see if the car has been clocked, if any faults exist, any major changes have been made, number of times it has been started even !.. as well as full functionality tests.
