Technical Has the cam belt been changed ?
What you do is call a fiat dealer (not the one selling it !) and request a WRITTEN DETAILED quote for a FULL service at 5.5 years with xyz miles - tell them you want everything done as per handbook - including cambelt.
That includes brake and clutch fluid change, oil, filter, air filter, plugs, and anything else,
give them the registration number and mileage.
Also consider tyres, clutch, exhaust, brake pads, discs, shock absorbers, suspension bushes, - as things you may have to spend on in the near future depending on condition - if you ask mr fiat to quote you for checking all those, that is a good start.
When you get the written estimate, use it as a bargaining tool and also a learning exercise,
Tell the the quote is to include time/labour and parts breakdown.
Now you know what SHOULD be done, then you can decide what you are going to do. - it is a good negotiating stance.
I would estimate around 650 -750 if it need nothing else apart from cambelt - which it DOES need.
Yes, you can get it cheaper elsewhere, but caveat emptor. !!!
You may well pay less and get less. you may be lucky though.
ASK THEM.. get quotes. I posted the VIN number for you - but they or anyone can get that from the reg number.
personally, I think that is rather expensive considering the sump change is next to no time and access is no issue with the work involved, the 'fan belt' and waterpump' would be occupy the same time timeframe as the chain replacement, the service, you say is nothing apart from a few checks.;) the oil change again occupies the same time frame.
Did you get a quote, in writing from Fiat first ? it would have listed time allocation per job as well which is useful in comparing prices
Besides that, the point is that if you are negotiating a price with a fiat dealer for a fiat car, you use fiat prices and parts to negotiate a discount.. Preferably, you should use them also for work, but that is up to you and how much you trust the person doing the work. It is all well and good until something goes wrong. - your choice at the end of the day.. your money.
3.9 hours according to Fiat for a timing chain on a diesel... during that time he would have removed / replaced fan belt as you called it, water pump also - so no cost there.
That's a lot of money in my book. but again, your choice.
btw, if anyone needs a fiat / alfa etc flat time quote as per their system, let me know. I have most models listed - the new panda is there.. this is the HOURS / MINUTES that fiat will quote for, it is a good guide when comparing quotes from other 'garages' as they should be cheaper in hourly rate but the time taken the same or more or less
On the 1.2 belt, it is 2.25, for the belt, so I would imagine the 16V to be in between on time. (ah, found it, 2.55) - so, about 1.5 hours difference...
there ya go..
I phoned two main dealers and asked for a quote for the timing chain. Neither would 'quote' but said the cost would be "Between £300 and £600." According to an article in This is MONEY.co.uk written in September 2011, the average hour of a mechainc's time is £80.44 with...."On average, a franchised dealer charges £95.83 an hour....." Rounding everything out, a timing chain taking 4 hours and costing £95 an hour would be £380 plus an average (EBAY price) of £70 for the chain kit would give £450. A water pump (again EBAY price) of £42 takes us to £490 plus alternator drive belt (happy now?) a tenner. So we're over £500 now.
EGR valves seem to have a mean price of £150, again on EBAY which equals around £650. 5 litres of Selinia 10W40 engine oil is around £70 on EBAY. I'm guessing at the prices here, but there will probably be about a tenner each for oil and air filter.
So, roughly we have:
Timing chain kit £70. Labour £380.
Water pump £42.
Belt £10.
EGR valve £150.
Oil £70. { £270.
Air filter £10.
Oil filter £10.
Sump pan £200.
Anti-freeze £10.
£582. £650
VAT @20% £130.
= £780
£582. + £582.
£1362.
Had to guess at some of the labour costs, but I will not believe for one single moment that a main dealer will carry out two tasks at the same time. If changing a fan/power steering/alternator belt and a water pump, they will be charged as two separate jobs.
There is another problem. Based on past experience, with one exception, I wouldn't trust a FIAT main dealer to change an oil filter which is the kind of thing apprentice mechanics are taught to do in the first few weeks of their apprenticeship. I do not trust them to carry out even the most basic of tasks and was very, very pleased there were no warranty claims. I consider them to be untrustworthy, overpriced and largely incompetent.
You need to get a written quote, and yes, they will carry out two jobs at the same time if one job encompasses the other.
You do not have to use selenia, your egr was probably not knackered - usually they just need cleaning - but thats an aside ;) . Phoning up and actually getting a written / timed quote are two separate issues. Perception of the quality of work is also highly subjective. I find that 95% of ALL 'mechanics, backstreet 'italian' specialists, main dealer, or greasy floor under the arches are ALL total con men... however, the main dealers are less of a total con artist than the rest - again only my opinion, as in that is what 'I' consider'
I think you assume too much negativity re the main dealers without actually getting a genuine written quote. Perhaps you had a bad experience ? - so what ? so have many here have very bad and expensive 'experiences' with back street alleged 'specialists' . get quotes. compare like for like. a 70 quid ebay timing chain kit is NOT a fiat timing chain kit. it will not last as long or may well fail prematurely. You have no idea what you are buying off ebay whatever they say on the box.
But of course, it is totally your choice to spend/ invest or waste money wherever and however and with whoever you choose.
You are entitled to your opinion. About the only thing in the UK you are entitled to ;)
OK here's some actual info for you.
Cambelt + tensioner + water pump
Main Fiat dealer quoted me 350 incl VAT.
Local well respected independent quoted me 240 incl VAT
Oil/filter change will be about 50 anywhere.
The rest of the 'big service' :D is mainly checks and topping up if necessary. The safety related checks (brake discs, pads, pipes etc) are checked every year at MOT time anyway.
Most local garages will give your antifreeze a check for free and only charge you if it needs attention (not expensive anyway).
Plugs, air filter etc - do it yourself for peanuts if you really want but missing them for a year won't do any harm.
Honestly, if you listen to the dealers then of course they will be more than happy to take a massive wedge of your money for doing next to nothing. This is a Panda for goodness sake - talk of spending 8-900 is crazy in my opinion.
However - it's up to you :rolleyes:
By the way - service stamps from a main dealer or otherwise are NO GUARANTEE that everything has been done properly, learn to DIY for real peace of mind (y)
Been servicing my own cars since i first learnt to drive and apart from a few issues that were inherent weaknesses on a particular car I've never had a single breakdown or mechanical failure.
So :D, with 1 quote, you got a better deal from fiat at the end of the day (as they will use genuine parts - not genuine chinese crap) - if you make a few more phone calls to other local fiat dealers you will probably get even better deals.. but 350 is peanuts anyway, only a few tanks of fuel.
No contest there really. Far better than Luigi at 'dodgy motors ltd' :ROFLMAO:
See what you mean regarding the relatively small difference in quotes - this means that the dealer was only 46% more expensive, and I'm sure that phoning round main dealers AND indies could get better quotes. The belt kit from the highly respected local garage used a Gates belt (top quality make) and an SKF tensioner (top quality make). You do know that most Fiat parts are not actually made by Fiat don't you? Like all car manufacturers they use supppliers to make their bits - such as - er - cambelts, tensioners etc.
I think you are confusing your Portugese experience of Fiat Vs Luigi's with Rip-off-UK-Fiat vs Competent Independent Local. :eek:
But hey, each to their own (y)
Personally, I don't use any of 'em - I do my own :)
I like the last bit :D - absolutely, where possible, do your own, I used to, I dont so much now as I can earn more when I want to than the fiat dealer charges so I can do clean electronics work while he can do the 'motor' (y)
IF the quote was for genuine parts, then great, but most of the great unwashed, unfortunately, don't have a clue and will just nod and accept cos the price is lower. They have no way of telling what quality of work is done or indeed the quality of the parts. As I have said before, word of mouth is not good really, as often it is the blind leading the blind. One has to be reasonably competent to recognise competence in others. Most, again unfortunately, just go by 'He was a very nice man, a very very nice man'
I would estimate that around 30% of parts for sale on ebay etc are counterfeit crap. The figure is probably far higher.
There are issues in Portugal too with main dealers - go to Oporto or Lisboa, and you will be well stitched. ! it is the local main dealers (often multi marque here) that you get the absolute best from.
Even went there to book it in for its 120k Km service today and buy a sidelight bulb - 0.68 Euros, fitted :cool::eek:.. took him longer to print the invoice..
Then went to local supermarket for other items, they sold side light bulbs.. 1.57 Euro EACH -- .... (120k service is 146 Euros all in). Including Selenia !
On the last service, a problem was picked up with the wiring to the left front sidelight from the body computer. contact broken in body computer plug (grey one in footwell) - new loom part ? -- naw, 2 new contacts in ecu plug !! - .. nothing extra to pay. I somehow dont think that would have occurred in the UK at ANY garage,,, but again I digress, you have the right idea, if you want it done right do it yourself !!! or move over here... (y)
I think we are heading to some sort of agreement here! :hug:
If you are careful and/or you know someone who can ask the right questions then an indie can be OK.
If you haven't a flipping clue then maybe you are safer with a Fiat Main Dealer.
Best of all get off your arse and learn to DIY :chin:
I was at my local garage for an MOT last weekend (not for the 100hp). The garage owner saw me arrive and said 'just a minute, just dealing with this customer'. I learned (whilst chatting to her) that she had nipped in on spec after noticing that she had a sidelight bulb out. He replaced the bulb which was definately dud - no difference. He checked the fuses - no joy there. He pulled out the light fitting, checked and cleaned the spade connector, no change. He looked closely at the bulb clip and noticed that the earth casing was a bit corroded. A bit of wet & dry and success. He apologised to the lady for taking 10 minutes to find it and charged her 1.99 for the sidelight bulb. :worship:
THAT is how you get customers !!! :D
Nice one.(y)
As I stated previously, I rang two main FIAT dealers and asked for a quote for a timing chain change and both said: "Between £300 and £600." Admittedly I didn't specifically request a written quote but unless I walked through the door I wouldn't have done.
The two main dealers I've used for servicing both stated Selenia oils as being used on the invoices.
To put some form of perspective on my attitude to the dealers, I bought the MJ in March 2005, when I went in to the showroom a few weeks earlier they only had two MJs as the launch date was a few days away. They got me one from the compound to test drive and the salesman apologised for the wax and plastic as it was destined as their showroom launch model. We did a deal on that car as it was in the colour I wanted and had the alloys I wanted as well. They also fitted the factory rubbing strip from the Eleganza. It was ready for me with a few gallons of derv in the tank as well.
As I bought it from Priory in Urmston near Manchester and everything went so well, I had the first service carried out there as well. They underquoted me yet when I pointed that out to the receptionist she spoke to the Service Manager who agreed to charge me what I had originally been quoted.
Unfortunately, by the time of the 2nd service the dealer had closed down so I went to Stoneacre in Hyde. No problems, which in theory there shouldn't have been.
As the warranty was up by the time of the 3rd service I took it to a local garage in Stockport recommended by a friend. The job seemed to be ok, until the next service.
The 4th one was carried out again at Stoneacre because they wrote to me with an offer I couldn't refuse. When I picked it up I asked if there were any problems and it seemed there was one. The oil pump was leaking and when I asked for a (verbal) quote a figure of "About £220" was forthcoming. Odd how these all contained the word "About." I could see oil down the front of the block, but there had been none on the ground where I parked and the oil level has never been below half way on the dipstick even when it went in for a service.
I kept an eye on the level over the next few months and then found myself at Heath Road Garage in Sandbach to look at an Alfa 156 he had for sale. I mentioned the oil leak and he put it over a pit and had a look from above and below. He said that although there was a small amount of oil on the pump, that wasn't where the leak was coming from. He said it came from the oil filter where the seal on the filter hadn't been seated correctly. He gave the front of the block a clean and said keep an eye on it. He serviced it at its 5th anniverary and there has since been no oil down the front of the engine, this month is the 9th anniversary of buying the Panda and since that day in Sandbach another 40,000 miles have been covered, still on the original oil pump.
So that begs a couple of questions. If oil was visible on the block on the day Stoneacre diagnosed a leaking oil pump, does that imply that the filter was already oozing oil from the badly fitted seal from the previous service? Not only that, as it was still doing it several months after a main dealer service is there a suggestion that not only did the dealer mis-diagnose the fault and quote for a job that didn't need doing, but his mechanic still didn't fit the new filter correctly? Or worse, that he didn't replace the filter at all.
I put this to Stoneacre who stated, and I quote: "We don't do that kind of thing." The Service Manager wasn't interested in inviting me to the garage to discuss the matter, or communicate with me at all afterwards either by letter or phone call.
A few years ago, a colleague who was running a Multipla returned the car to a main dealer for a factory recall to the suspension. The work was carried out and a few months later it started making a noise (can't remember what kind) and as it was due a service he took it to a long established independant mechanic near where he lived who had carried out his maintenance for years. He diagnosed a problem with a suspension mounting that was allowing contact between metal components when moving on full lock and recommended he take it back to the main dealer.
When he did he was asked how he knew what the problem was. He obviously said he'd taken it to his local mechanic who'd diagnosed the problem. The dealer then alleged that the other mechanic must have tampered with it and therefore neither FIAT nor the dealer had any liability and he'd have to pay to have the fault rectified. He went back to his local bloke who did the work and the car ran without fault for another 2 years and 30,000 miles until it was written off by a BMW X5 in a supermarket car park.
He then bought a Renault Espace Scenic, followed by his current motor a Skoda Roomster. As you can probably guess, he's never been near a FIAT again, and I have never been to a main dealer since, and apart from the first two services, I won't when I get my next car.
Heath Road Garages in Sandbach uses service parts by TJ, AC Delco, Bosch, NGK, as well as original FIAT/Alfa. As a matter of interest, the timing chain kit was a FIAT original as I was there when the parts van from Mangoletsi delivered it.
Well sir Beard, I can thoroughly understand your attitude towards your local main dealers !!
It really is unfortunate that these crooks can get away with it for so long. It is a fact though that there are some good main dealers out there, also, some good indies. but how the general populace is intended to know is beyond me. It is also unfortunate that you were treated in that way.
I am fascinated by you mentioning Mangoletsi. !! - I used to deal with John a lot in the 70's when I worked at 'Mini Sport' in Padiham at the peak of the stage and road rally era in the UK, he was making inlet manifolds at that time and made several to our spec, they were crude, but effective and very well respected, he was following on from his dad and his induction designs.. well done John !! :) - look at the company now. !
There is little pride of workmanship in the UK, little pride of anything, there is no real culture of any degree, it is just a huge melting pot that has yet to even soften the mixture.
You have organised crime moving into the very lucrative area of rip off copy parts with original markings, not just automotive, but everywhere, many vehicles are stolen for parts, the police are not interested, ebay even sell the goodies to steal the things in the first place.
It wasn't too long ago that the counterfeiters were into airline parts ! - some even found there way into Airforce one !. - That is the scale of the problem, they tightened up on that side a lot, but the auto trade is not regulated in any way worth mentioning.
So, yes, I empathise and understand your reluctance to use said dealers. You can do no more than stick with someone you trust, and hopefully he wont ruin that trust in the future.
There are many thousands or tens of thousands, of very happy customers of main dealers, good main dealers.. like doctors, they tend to be criticised when they make a mistake, not for the 5000 perfect jobs before, but your ones sound rotten to the core.
When cars get beyond warranty and are bought at very low prices in the uk, there is obviously much reluctance to pay what appears to some to be a lot of money for regular servicing. Hence the back street rip off merchants get in... you have a good one, but many have total cowboys with a good front. But, as with chinese rip off parts for any consumer area blatantly on sale, the gullible British public often buy the cheapest. The only reason this has been allowed to progress to a non recoverable level is that cars are in fact, extremely reliable these days. it is not due to the intervention of these crooks that the vehicle keeps running in most cases, it is usually the fault of the crook (indie or dealer) when it actually fails !)
It does help if your mechanic speaks English too. Last time I was beck in the UK, I struggled to understand many folks from shop assistants to alleged medical personnel - all from some dubious immigration path. Probably with dubious backgrounds and credentials too. In many cases I am surprised they didnt offer me the lost millions of the former ambassador to western Nigeria who was recently killed in a car crash leaving millions in a private account which I could be part to a huge share of... etc etc... :) :) ;)
I can't let that pass without comment. I've worked in engineering for 30 years and I can tell you that there is still fierce pride and outstanding expertise and skill in the manufacturing sector. I currently design electro-mechanical products for a niche engineering company that exports cutting edge equipment all over the world.
I have to say that you opinion of the UK is rubbish and may I remind you that your chosen country of residence has been teetering on the edge of bancrupcy for several years, only shored up by the backing of your leader in Germany.
I have a house in Spain, I go there regularly for my holidays, it's a nice place and the locals are lovely. Would I live there? Not a chance - the UK is still one of the very best countries in the World, despite the lousy weather :)
I accept the criticicsm of my comment re pride of wormanship, although I did say little, not NONE... but fair enough. (y)
However, your comments re Portugal are plain wrong old boy :eek: .. It is in a perfectly good and sound financial state. The UK is not exactly solvent....:rolleyes:
Ref SPain, I wouldnt live htere either lol :cool: - too many freeking brits.. :D
Galicia is great, but that;s about it for me and Spain, we lived there for 4 years and enjoyed it, but not my cup of tea...
Here is like a cultural breath of fresh air... looking at 3 houses tomorrow ourselves.. one a rather nice farm that would be ideal as it has a workshop (mancave) under it... :devil:
