Grievezy
So my drivers side washer ain't working. What I'm noticing is that the wee bit at the side popped out every time i spray front window and water sprays out that instead of the normal bit.. HELP.
Its forzen at some point and been damaged by the expanding water.
Can be obtained from Fiat and replaced cheaply.
At which point they'll just do the same thing usually. Best to give the inner end a little squeeze with pliers which makes it a tighter fit and ensures it never happens again, this is what the dealer did to mine about 4 years ago and they've not popped out since.
My last mk3 Golf GTi had heated washer jets, nice touch that.
on a slightly more serious note....
How is a heated washer jet going to stop the liquid freezing ? - for example -
At night, if it freezes, problem occurs, end expands allowing it to pop out yes ? -
Surely this is more down to the fluid mix..... ?
(I vaguely remember freezing)
Heat..................................................................................
But they're only hot when the car is going. The point @captainslarty was making is how does this help over night etc when parked.
