Technical 06 panda 4x4 Gearbox and Differetial oil changes
cjxn
Can anyone please advise on how and when to change the gearbox and diff. oils on an 06 Panda 4x4?
Many Thanks
cjxn
Not sure how, but i just got a garage to do mine. Selenia for the box and could only find castol in the right spec for the diff
I dont know about the 4x4 Gearbox but the 100 HP as two plugs one to drain then one to fill up. the drain one was the lower of the two at the rear end. the fill is toward the engine at the side. I change it right or wrong every year as a mechanic friend advised me to do.
It uses a Hex key to undo well at least the 100 hp does.
