MOT coming up fast so I thought I had better check my 9 year old multijet for the obvious faults. I jacked up the car, took off each wheel in turn to look at the shocks, brakes, and bearings. The offside front was last and I found that the rear rubber bush in the lower wishbone had so much play that it allowed the wheel to move almost an inch fore and aft. I have ordered a wishbone from my local car parts shop to pick up tomorrow. Although this would be a definite MOT fail there is no danger of the wheel falling off but I had no idea that the problem was there while driving. To check whether the bush is ok is easy, with the car parked with the handbrake on just try to roll the top of the front wheel back and forth, it shouldn't move much. Compare left and right sides as it is unlikely that both sides will fail at the same time. Also I found that an 18mm socket is required for the large bolts.
