Hello everyone,
Just joined this forum due to a starting problem with my Fiat Panda diesel(55 plate).
Went to start the car yesterday morning & It took quite a few attempts to fire off. It kept starting for a split second then stopping.
On closer inspection rain water had been dripping from a self tapping screw that goes through the bulkhead/scuttle panel & straight onto the top of the air box!!!
So took off the air box & as I tilted it, water came running out through the airflow meter! there was also a pool of water between the head & inlet manifold.
Took the air filter & MAF out and dried them out dried everything out & the car now starts on the button so hopefully nothing has been seriously damaged.
I have now replaced the self tapper with a nut & bolt with a couple of washers & rubber grommets on to stop the water coming in. Thought that would make the best seal, and will see how it goes.
I did a quick search of this forum first & noticed that it is a known problem (at least by us owners) but just thought by other peoples experiences is was serious enough to bring up again.
The thing is the hole & small rectangular shaped plastic clip that the self tapper goes through is pretty large. It might not have caused such a problem if the hole was a similar shape/size to the self tapper.
Or if the scuttle could have been attatched the the vertical face of the false bulkhead.
Also I think in future I will remove the air box completely when changing the filter as it seems trickier than most cars to get the top of the air box fitting correctly. So at least you can see if the 3 fingers are located correctly (worth checking yours, mine were not!)
Sorry that the post is a bit long but this is a really bad fault (when a part worth pennies could cause thousands of pounds worth of damage).
Thanks to all members for a great forum. Within 5 mins I had found something useful - Fitting a DIY boot light, will give this a go. Thanks Creamola .
Chris.
Chris.
