billythetipdog
- Nov 24, 2013
- 7
- 2
My '07 Panda 1.3 MJ with 64k on the clock lost power simply turned itself off at 60 mph yesterday - very inconvenient on the A1. It had been running for 90 mins and running well at 60-65 mph and showing 60mpg, heard/felt something something vaguely go 'thunk' and yellow injector malfuntion light came on immediately, oddly, the clock zero'd itself like the battery had been disconnected, so am suspecting (hoping) something electrical, rather than major £££ component at this stage
Engine turns over at normal cranking speed, 'nearly' firing, nothing oily dripping out the bottom. Bizarrely the car was with the local Fiat stealer the very day before, apparently having dpf de-clogged and eml code reset, (I say apparently as I'm not even sure my Panda has dpf) and other error codes rest, so at best, this is throwing me a curved ball in terms of getting a diagnoses together.
car had to be trailed to local dealer as it was after hours - I know on Monday Fiat will probably spin engine and check codes and assuming they'll check injectors/injector relay (?) cam sensor, etc unless there is a obvious evidence of perhaps slipped chain/bent oily bits. Its at this stage, I'm running out of inspiration, as to where the fault might be (new engine paranoia is setting in)
Any thoughts on a diagnoses welcome, and if anyone can throw light on whether my 07 panda mj has a dpf would be good to hear
