I have a 2005 1.4 Fiat Panda with intermittent long cranking problems. I've had the coolant temp sensor changed three times from three different part suppliers just in case the part was faulty - every time after it's been replaced, the car is great for about 3 - 4 weeks then returns back to an intermittent long crank when trying to start the car. There were no codes stored but the diagnostics were showing that the coolant temperature would start to rise then drop even though the fan hadn't kicked in. It would then rise again and rise further and only then would the fan kick in and start to show the regular readings that it should. The car drives fine otherwise.
Does anyone have a clue what else might need looking at? The throttle body has been cleaned and the battery is only a year old - I don't want to go back to the dealer as the last time I had to go to them, they said they'd replaced a sensor and hadn't and even then they diagnosed the wrong sensor which another mechanic identified straight away and replaced (knock sensor)!
Thanks in advance for your help - hope I haven't repeated a topic but I couldn't find another similar topic
