Hi everyone im having the purchase a socket to fit my panda front wheel hub nut.. think its a 32mm but just wanted to check as im def no mechanic lol.. many thanks
Just stick a tape measure across it from flat to opposite flat.
If you are not sure about it, why are you trying to disturb it? You will need a torque wrench to do it up again. Should use a new nut each time, then tighten to 240Nm/177lb/ft. That's quite tight. Guessiing will not do, if not right it can destroy wheel bearings, CV joint, disc.
