Seen a couple of posts covering corrosion to the offside wiper arm. Not sure, however, if anyone has tried to rub down, treat and recoat/paint? If you have, did you remove the arm to do the work or did you do it in situ?
Also if you did repair yourself, has it lasted, or has the corrosion/paint flaking returned?
I'm trying to make my mind up whether its worth taking the repair work route, or just buying a new arm to put on. Has anyone bought one recently and, if so, what was the cost - ePER indciates only around £15, but not sure how accurate that would be?
Thanks for your help.
Rod.
Rod.
