Turbo diesels can suffer a bit of smoke if the air/fuel ratio is imbalanced.
You can easily imbalance it via the throttle pedal, you signal for more speed, so it adds fuel, but it takes a moment for the air/turbo to catch up, which is why they'll always puff a little when you clog the pedal.
It's chicken and egg, you need more speed, so it needs more fuel and air, there's little control over the air entering the engine on a diesel, so fuel is added to make the engine speed increase and drag/push more air in.
A dodge MAF can cause issue, whether it's dirty or broken.
The air is measured on the way in before the turbo via the MAF (Mass Air Flow meter) but after the air filter and the fueling worked out and added (injectors) depending on other sensor readings, throttle position, temp etc.
So effectively a dirty air filter would limit performance as it would limit the fueling to the air it measures.
Air leaking out after the MAF via a split hose is another common one, often a hiss or a fart sound can be heard when under load.
The air is measured, fueling worked out, but some of the air has gone missing!
Wonky injectors with poor spray pattern can over inject or dribble.
Usually noticed at cold start with lots of unburnt fuel appearing white in the exhaust.
Prime suspect though would be the EGR, a headache of a device that most diesel onwers dread. Under certain conditions is meant to introduce exhaust gases back into the air intake to lower combustion temps (and Nitrogen Oxide)
On a steady cruise or over run, fuel injection is limited or stopped altogether but air it still pumped in (as mentioned, there is no control over air), this leads to higher combustion temps and production of the green house gas Nitrogen Oxide.
The EGR should open at these points and allow exhaust gas which lacks oxygen back into the air intake/cylinders, which will lower the temp of combustion.
I theory, it's great, in practise it's a friggin headache.
Soot (from the exhaust) and oil (from the crankcase breather that is plumbed into the air intake) combine in the valve to produce the nastiest substance known to man, this bungs it up to restrict air flow or jam it up so it fails altoghter and sticks open.
This is one off a Jag being cleaned, believe it or not, it's actually pretty clean to start with, they get much worse!
http://www.jaguarforum.co.uk/f26/egr-removal-cleaned-photos-36133.html
