- Jul 3, 2013
- 33
- 8
Looking to replace the rear dampers on a 100hp due to the usual failure of the bushes in the original items. Already had one attempt using KYB units however the fitment was not quite right so am looking for alternatives. As far as I can see there are Bilstein, Koni or Fiat options. Obviously you'd have to be mad to put more of the Fiat ones on, so really only the other two choices.
Any ideas which of the Koni STR.T (£94) or Bilstien B4 (£104) are the ones to go for?
I note that many people seem to end up with dampers intended for the standard suspension, i.e. not 100hp specific. The Bilstein 19-197227 is the unique to the model, whereas the Koni is not. Don't know if it makes much difference, I get the impression most of those who have the non-sport ones don't even realise.
ETA: The Koni STR.T option is also listed for all Panda variants so is not 100hp specific - not sure whether the Sport variant would be a better match. Sachs do no list 100hp dampers. Seems like the Bilstein is only correct option.
