Hiyar
I've been roped into fixing a friend's 2004 Panda (engine as above). It sounds like it doesn't have any compression and after taking the cam cover off I've found the cam belt doesn't look too good - It's supposedly just had a new one and a tensior fitted by the PO (a garage but it was a private sale. It would appear that it's been rubbing against something and it's tight up against the block and head rather than running along the middle of the cam pulley.
So I have a couple of questions as follows;
1. Is this an interference engine? - I think the timing has slipped so am I looking at bent valves?
2. Are any special tools required to set the cam timing?
3. ARe there any pitfalls I should be aware of - Someone else has managed to balls it up, I don't want to do the same thing!
Thankyou!
Thankyou!
