My 4x4 has at various point shown the engine warning light. On one occasion it turned out to be that a spark plug lead was damaged, but other times, no apparent cause. However, last time (couple of weeks back), the following day the car was clearly running on three cylinders. After proving to myself that ignition was all fine, used multimeter to test resistance of all four injector coils (ie measure resistance across the two terminals revealed after unplugging yellow plugs from injectors). Three showed 16ohms, last showed open circuit -- ie the injector had failed.
In fact, it was also clear that the black socket the plug fits into was 'loose', suggesting that the movement was causing the occasional warning light issue, and also explaining slight misfire I sensed now and again. You may well have the same issue. (Mine was the cylinder nearest gearbox). No idea how the connector became damaged. Having got the part, the repair was quick and very easy to do. Car now running like a dream.
New injectors are over £200 from Fiat -- but I bought four (still on the injector rail) online from a breakers (my cars old and tired anyway), and fixed for £30...
Hope this helps
P
