Technical 2008 fiat panda eleganza
Kee Speedgear
Hello,
My Panda Eleganza is a dual logic gearbox and just recently I have discovered 2 hiccups -
Problem One
the power steering intermittently fails, fortunately a turn off ignition and turn back on clears the problem for a reasonable period of days/weeks.
Problem Two
The transmission fails, unfortunately the on/off doesn't work for at least 2-3 minutes.
Anybody out there had a similar problem or got a good solution?
Regards
Keef
Hi;
Nah, battery is AOK - all unnecessary accessories eg Air Con turned off.
Keef
Don't dismiss the battery. Our Panda had intermittent power steering failures but the battery seemed fine, it wasn't old (just over 3 years), car always started promptly, no other issues, voltage and charge were good. Steering would fail at least twice a week and ignition off and on would normally reset it.
New battery about 2 months ago totally fixed it (and it wasn't just disconnecting it for a few minutes to let the electrics "drain").
In fact I didn't believe it could be the battery so swooped it for a nearly new one from one of our other cars for a few days before buying the proper Panda one as it is an unusual size.
Hi just read your post and there is a shining light bulb over my head because my son(In Africa) has talked about just this problem with other Fiats. So I will follow your advice!!
Many Thanks
Keith
XXX
