Right, someone must have done this by now, given the availability of 16v engines from other models in the Fiat range...
Who's swapped a 1.1 or 1.2 8v out of a panda, in favour of a 1.2 or 1.4 16v, or bigger?
Are the 8v and 16v mounts the same?
Does the 8v gearbox bolt up to the 16v engine?
Are the sensors the same? Can you use the standard 8v ECU, albeit remapped, to run the 16v engine?
