I've found some ronal turbo's they fit a 500 and therefore I would assume ok on the panda?
Thoughts?
Dev
It's not a foregone conclusion - there are significant variations between the 60hp FIRE fitted to most 1.2 Pandas & the 69hp FIRE in the 500 - the intakes & compression ratios are different for starters.
I'd guess it could probably be made to work, but it won't be plug & play & the mapping will certainly need to be changed.
FPMSL
my money is on the wheels
FPMSL
You just might want to have a look at this thread from the 500 section before committing yourself. It's very relevant - this started out with the fitting of some aftermarket wheels... just keep reading...
Doh....:nutter::nutter::nutter::bang::bang:
Now I'm laughing with you
J R Kitching - I am staggered that you have not mentioned the de-merits of placing fatter wheels/tyres on someone's 1.2 Panda.
From a chap who wears greased pram wheels on his motor to eke out that last drop of petrol, this is an incredible oversight. Shame on you.
By the way - I was actually thinking the guy was fitting two turbochargers. Had my eyes shut trying to think how that'd work in the Panda bay.
My question was however if the fit and offset is fine for the 500 will it be ok on the panda? I think it should be as 500 wheels do fit on the panda.
I've a 100HP
It's in the pic
< here
Hi Demi,
The can be any offset from 28 to 35
What offset is the panda 100hp
They are 15's 7J
I'm also considering borbet A's in same fitment
