LeoJensen
Hi
My car stopped running with my wife in the drivers seat.
She explained it was running rough, lost power and finally stopped and refused to restart.
I can make it run for a few seconds, if I pour some fuel in the throttle housing. It sounds fine, so ignition seems OK.
I tried to relieve the fuel pressure using the schräder valve: No pressure.
Fuel pump is now out, and it does not run when I supply 12V to it, so I guess the diagnosis is clear: Dead pump.
Next is then: How to repair it ? I can see the pump/sender unit is sold complete for a small fortune except from this one on Ebay. Will it fit, it looks the same ?
http://www.ebay.co.uk/itm/ELECTRIC-FUEL-PUMP-FIAT-PANDA-169-1-1-1-2-1-2-4X4-1-2-BI-POWER-/151021924945?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item23299bb251
There are also seperate pumps avaiable, but can it be replaced w/o breaking the plastic parts ?
http://www.ebay.co.uk/itm/Fiat-Panda-169-1-1-1-2-fuel-pump-repair-kit-NEW-/261166137290?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item3cceb6ffca
I will try to contact scrapyards tomorrow, but there are not one nearby.
I broke the large plastic retaining 'nut' when trying to loosen it. I guess I should make a tool to fit it to tigthen the new one
