My Panda is a 2006 1.2, with throttle cable, so hopefully is the same as yours.
Pic009 is looking straight at it from the front of the car.
Pic010 is looking from the driver's side of the car, top connector is presumably throttle position sensor, not sure what the lower one is to its right.
Pic011 is looking from the opposite side, connector is to the MAP sensor I believe.
Pic012 is a close-up of the MAP. Pic is upside down to give a good view of the numbers.
Pic013 is looking down onto the MAP, also showing the blue pipe and a connector behind that, which presumably operates the purge of the charcoal canister. (Fuel tank breather system)
Hope this helps. If you need more info, post here or PM me.
