I think all Pandas and 500 have had, or will at some point get the dreaded wrinkly steering, where the lamination starts to peel and wrinkle from the leather. if your car is out of warranty, and want a suggestion of a cheap fix (cost me nowt), which you may or may not like ..read on. be warned takes a good half to a full day to do.
My 100hp started to wrinkle about a year ago, I lived with it, but its got so bad, and not having funds to buy another or get recovered, I looked at what i could do. I took a brave step in trying to remove all of the lamination, as i noticed that where it had peeled off, there was a nice bit of leather beneth.
Tools needed.
Heat gun/hair dryer may work
dremel (or copy) with sanding barrel attachment
800-1200 grade wet and dry sand paper
alcohol cleaner (or white spirit)
Leather cream/conditioner
I recco most blokes have the above in their shed.
firstly stage 1, start by using heat gun on outside edge leading to the front of wheel on a medium heat, working in small sections, as it bubbles, simply rub off DO NOT DO INNER OF WHEEL WITH HEAT GUN OR YOU WILL MELT THE STITCHING !!.
next Stage 2, fire up the dremel, and carefully sand the lamanation off from the inside of the wheel, starting away from the stitching, finishing where your peeling of stage 1 stopped. the fronts of the spokes are the same, as is the rear of the wheel. (although I did not do the rear of the spokes, but you may) Again KEEP SANDER AWAY FROM STICHING !.
once you are happy that all the accessable lamination is off (and dont panick it this stage as it will look shocking. Stage 3, using a rough grade of wet and dry, and working down to a smooth grades, sand the areas you have been over (take your time) it will start to look good.
Stage 4, there will be a glue residue left over, so use a alcohol cleaner of simular to clean areas, get to a level where there is almost no trace of this glue.
Stage 4. with all the heat and rubbing, you need to feed the leather again, I used some auto glym leather treatment, followed by leather wax, apply loads and let it soak in.
thats it your done. I personally just done the dimpled areas only, and left the original smooth areas top and bottom, thus giving a 2 tone black/grey wheel. I MUST SAY IT FEELS LOVEEEEELLLYYYY.
Tools needed.
