doctorchris
Established member
The rear discs on my Cross have looked very heavily corroded for a while, so today I stripped everything down and fitted new pads and discs. The pads on the driver's side were worn almost down to the metal but on the passenger's side there was plenty of friction material left. I had noticed that the centre of the driver's side wheel was rather warm after a journey which was consistent with the over-use of the pads on that side (I say this rather than under-use on the passenger side since the discs and pads had only been in place for just over 12,000 miles).
However, nothing was seized at the strip-down and the calipers seemed to be in good order so I have put everything back together after a good clean, naturally with new pads and discs. I also bled the entire braking system with new brake fluid.
Now, after a short run in town, so moderate braking, the driver's side disc is hotter than the passenger's side. So the possibilities are
1. Driver's side is binding. Against this the car accelerates well and fuel economy is as expected. However I will not rule out a faulty caliper or brake flexi (a "one-way valve" effect can occur).
2. Passenger's side is not braking sufficiently. However braking is taking place on that side as the disc is warming and showing evidence of pad contact across the whole braking surface.
3. Some electro-mechanical problem with the ABS or virtual LSD (limited-slip diff) functions leading to imbalanced brake application.
MOT soon but this imbalance may not even be detected as Panda 4x4s cannot have their brakes tested on the rollers but a road test is used instead with a deceloremeter called a Tapley being used. OK, I might get through the MOT but I want a solution to the brake problem.
Sorry about the long and wordy post, just wandering if another 4x4 or 100HP has had this problem.
