babbo_umbro
Established member
Just back from our spring time in Umbria. Went out mid-April returned 26th June. Total mileage for trip 5,427. Average mpg just on 40. Car didn't miss a beat. Cruising on motor ways at 4000-4500 rpm - speed cameras permitting. Very pleased with the rear Koni adjustables, fitted just before we went, control of body movement is much better - there are numerous viaducts on Italian roads, often with poorly aligned transverse or diagonal ridges between concrete sections - on standard rear dampers these cause noticeable lurch, which can be interesting on a long bend at 90+ with very large lorries beside you and two narrow lanes - but the Konis manage them much better. All types of road in parts of Italy are now in a shocking state - there are pot holes in some roads around Spoleto that I have been wincing at for over twenty years, almost become old friends, now joined by many companions - so the 100HP's firm ride can be a bit of a bore after a long day at the wheel but better than wallowing around on soft suspension. (We detoured through leafy Surrey on the way back as there was an enormous jam on the M25 east of Leatherhead and I must say that the roads in the Bletchingley/Redhill area are not much better.)
I had to add a litre of oil after about 2,000 miles - car had had full service just before journey so this was slightly worrying but level has not changed significantly since - so presumably was under-filled. We also went to Puglia - heel of Italy - for the first time. Interesting trip - over 1,600 miles in all - very good value eating out - discovered Falonghina wine - single grape, white, crisp, citrus flavours, from Puglia and Campania. Some parts of the area are surprisingly green, with massive olive trees - the size of a mature oak and totally different from those in Umbria, which are much smaller. The south is a different country - we went to several large villages/small towns that appeared to have no commercial activity at all. The Gargano peninsula is lovely but getting from place to place is tedious - narrow winding roads with psychopaths coming the other way; Maglie and Lecce are fine cities; the area round Lecce - right down in the heel - I didn't find very interesting - flat with potentially beautiful coast line marred by horrendous ribbon development (as I'm not in the least interested in spending time at the seaside and on beaches, the fact that they were visually b-----ed up meant that they had no appeal whatever). The olive oil from down there has a less peppery flavour than that from central Italy and has a more fatty feel in the mouth. We spent a couple of days in a great organic agriturismo (farm with B&B) just south of Rome on the way back to Umbria - everything consumed produced by the farm - run by a young brother and sister on a wonderfully sustainable basis - just what Italy's about.
It was very hot in the south and in Umbria for the last few weeks - over 33C/90F every day so air con was working very hard.
After coming out of the Tunnel on the way back I was amazed to see a twin - Electroclash 100HP - a few miles up the road - lots of light flashing (headlights, not just sneaking a bit of flesh into view) and waving - one of a handfull of 100HPs that I've seen in over three and a half years of ownership.
