Thanks again Jon, the pump goes when you open the door, no failure notice on the dash but the car wont start and the display just says to press the brake pedal, the oil level is on the minimum and i have noticed a few drops on the floor from the pump area, what oil do i need to top it up ?, also if it is anything to do with the oil and that gets fixed would it remove itself from gear ? thanks again.
