My rear tyres wear nice and evenly. I only use Continentals.
However, my latest front tyres have done 15,000 miles and have 4mm tread in the middle and outside, but only 1mm on inside. This happened on the last set of tyres and I checked the front wheel alignment with a modern laser system and my old Dunlop alignment tool then and it was OK (ie parallel).
I've just checked the alignment again on a laser system and its still OK.
I've set out to measure the camber (ie angle from vertical) of all 4 wheels with the method in the photos.
Basically 6mm difference in the horizontal dimensions at the rim is 1 degree. The rears measured 3.0 and 3.2 and the fronts 5.9 and 7.7 mm. Rears were done as a control, and are certainly believable. So basically there is 1.0 degree of negative camber on front and 0.5 degree of negative camber at rear.
Has any body got measured their camber?
My thoughts are that the extra mass of the MJ engine makes the suspension flex a little more, and also puts a bit more stress on the thin tyres.
Does the Haynes manual have camber values ?
