Hi there.
I own a 2005 Panda 1.2 8v.
The wheel light on the dashboard is "ON". Still, the powersteering is working properly even CITY function.
I've scanned the powersteering ECU and found the following error:
C1002 - Steering column motor torque position sensors
The parameters are:
Steering axal position: 0 (always)
Steering column position sensor: Not present
Current absorbed: Too high - this changes for a short while into Normal from time to time.
Ecu voltage: 13.90 - 14
Alternator status: recharging
I would need some advices from you.
Regards.
The parameters are:
Regards.
