babbo_umbro
Established member
A picture of the offending part would help as it may be that there are other possibilities - is it a little shaft with ball-joint sockets at either end, for instance? These appear everywhere and are often in steel with threads at one or both ends to adjust the length. If that's what it's like, it's not difficult to make one yourself.
Failing that, getting one made must be the best solution, surely. Two probably wouldn't cost much more than one, as it's set-up cost that's the bummer. If so, I'll chip in and split the cost with you for the sake of having a properly-engineered one to hand when the (apparently) inevitable happens. One or two others might do the same and we could split the cost more ways.
