Currently running Spax lowering springs (-25mm) on the 100HP and I am very happy with them.
Handling is very much the same but with a reduction in pitch and roll when braking and cornering. The drop in ride height also makes the car look better IMO.
I would not go any lower on springs alone though. If your looking for a serious drop then go down the coilovers route!
I can see that lowering the car would/could reduce roll - though I wonder if it's a perceptible difference or an imagined one that (if it's there at all) is the result of a stiffer, perhaps more progressive, spring. But I question whether lowering on its own - once again as opposed to a stiffer spring - would give a noticeable reduction in pitch, unless, of course, the front of the car's rubbing along the ground, which would certainly reduce any pitching.
You don't mention if you've changed the dampers.
I've lowered my previous 3 cars just with springs & kept the dampers standard. Does it improve the car that much as it is fine with the factory setup..?
Pretty much. The 500 suffers from the same issues, mine even worse due to having 16" wheels.I'd have thought this is the worst combination for the 100HP - higher rate springs working against already weak dampers, plus very limited wheel travel -sounds very uncomfortable and bad for the roadholding as well as the ride. The general opinion seems to be that the best single mod is to increase the rebound damping on the back - mine should be fitted tomorrow so I'll find out - adjustable Konis on the front seem to be the next best mod, followed by these dampers and more progressive springs that reduce the ride height slightly.
My plan in the future is to either fit a Koni sport kit or a set of Bilstein coilovers to my 500 to sort out the frankly rubbish suspension.
Well I'm of the opinion that if I'm going to spend all that money then I may as well make it handle quite well. Lately I've been taking the 500 for drives over the moors and the standard suspension really does ruin the experience. The Bilstein's are meant to be pretty goodHave you considered FSDs? I don't follow the various 500 sections but I assume the Abarth area is full of chatter about them.
