General Panda 1.2 4x4 Front Disc Replace
TTR
Established member
All,
My 2007 plate has 30,000 miles on the clock and is still on the origional front pads and discs. I replaced the rear pads last year as i had a spare set around and whilist the brakes were off thought i may as well. the disc was in good condition.
I made a note to check the fronts this weekend, the pads are now getting to a point where they need replacing, the disc looks in good condition but it has developed a small lip indicating wear on the disc itself. Firstly i want to check the max and min disc thicknesses before i set about replacing both components - does anyon eknow ?
Apprecaite many will say replace both at the same time, total cost for both pads and discs is £70.00 but before i do i want to check wear as it may be superficial.
Thanks in advance for any assistance.
Jrkitching,
many thanks for the link, just what i was looking for
Alternatively, you might like to look here:
http://www.shop4parts.co.uk/?name=s...9&secondary=10&opts=65&btnViewProducts=Search
The front discs and pads are an easy replacement, provided the combined wheel locating pins and disk retaining bolts haven't seized. There's a few other posts about this around the forum. Surprised you needed to replace rear discs. I didn't need to do this until at least double your mileage.
