Hi. I drive a 2008 Panda active 1108 petrol. It's into it's 4th year extended warranty.
My engine management light has been intermittently flashing at me, quite rarely for about 3 months now. I think it had been incidentally since I'd had a full service done, at Halfords ... *Lightning strikes*
It'd typically flash about twice on every 3rd journey I'd make. I was trying to notice patterns in when it flashed at me, most often it'd occur going over speed bumps but also on some innocuous flats.
I've taken it into the main dealers about this 3 times now. Each time the dealers diagnose no fault and testify testing it S*dsLaw it ran perfectly OK. Before the most recent visit, the engine cut out and it broke down, twice. The 2nd time with it failing to restart for ~20seconds and thereafter the EML being up permanently. I called my main dealers &they said call out my breakdown people, which I did - They gave a 'temp fix' suggesting a sensor fault, gave me the code to give. Ofcourse this action wiped the code data on my ECU &dealers have given the all-clear response once again.Saying the errorcode given is not useful. Oh&the EML has randomly flashed a couple of times again since.
So now I'm concerned that if it continues to flash, my dealer can do nothing, &if it breaks down my breakdown guys won't attend for the same fault twice for free. I'm assured it would be safe to drive to the garage so hopefully that'll work out. Oh and my dealers has helpfully told me they'll close this job on Wednesday, so I can expect further charges thereafter.
One of my major problems here is that my handbook tells me that this intermittent fault indication should register with the CPU and be fixable with the main dealers. But it's aparently not registering a fault. This is misinformation from the handbook at best and suspected warranty costs evasion at worst from my main dealers, or some kinda tampering from Halfords as a possibility. All at risk to the health of me and others, if it breaks down avoidably in an unfortunate location.
I don't know if there's a scanner I could buy to help prove this fault? Or if there's any other actions I should be suggested to take? I've had very little piece of mind out of all this and am not sure what I should be doing next.
Thanks.
Thanks.
