Panda newbie
- Mar 17, 2012
- 8
- 1
Were new panda owners, she's got less than 5K miles and registered in 2008.
Intermittent fault has started occurring. Its frequent and causes the engine to cut out at idle and judder when driving but it only happens every 1-5 minutes. Engine management light flashes up but does not stay on long enough to pick up a fault with my laptop OBD reader.
Had a mobile mechanic look into this and previously the fault light stayed on. The mechanic got a P0606 (PCM/ECU fault). He checked and cleaned contact and diagnosed a new ECU recommending i should take it to a fiat dealer. I decided against taking it to Fiat due to the high cost
I've now purchased a new ECU and coil packs and was ready to fit however can't get the fault light to stay on so i'm not convinced its either of the parts
I've had the laptop on and can't see any problems showing on the sensor reading however i'm an engineer but not a mechanic
Anything else i can check with the laptop before i go to the expense of fitting? I'd be gutted if it wasn't fixed after fitting the parts
Thanks for any help
Dave
Thanks for any help
Dave
