Thunderbug
Established member
I want to upgrade my side / parking bulbs for brighter ones, what is the code or part number so I can fit Xenon Bulbs.
If your car is an Eleganza with the multi-function dash, you'll get Lights-Out alarms if you fit nice LED versions. These cars are more sensitive to bulb swaps thaan the Dynamic or Active versions. I have one of each and know that Dynamic-spec CANBUS will not whinge...
.... but if you buy the CAN-safe version (whiich just adds a resistor into the circuit) you'll be fine.
Not on my 4x4 - lovely bright technical LEDs go straight in and work a treat. Try the same on the Eleganza and it warning beep city unless the CAN-friendly adapters are used.
