Hello everyone, I’m having a spot of bother with my 2004 1.2 8v fiat panda dynamic. For the past 4 weeks I’ve been having problems with idling when the car is warm and warming up (from a quarter, to half way on the temp gauge). After 20 seconds or so whilst sitting in traffic the revs go up and down between 500 and 800 RPM.
Initially I plugged it into fiat ecu scan as soon as it started and didn’t find any error codes. Nevertheless, I did a self-adaption reset out of good measure and all was very well for about 2 weeks until the problem started again. I should also note I changed the spark plugs about a 1,000 miles ago (NGK ones) and put some new fiat HT leads.
Now I’ve just had it plugged into the computer again and there are no error codes, but my suspicion soon turned to the lambda sensors. It’s funny I should bring this up because 2 years ago (@40,000) I had the same problem and it lasted for about a month before the engine management light came on and it turned out there was no signal from the pre-cat sensor. So I replaced them both and haven’t really had any bother since until a month ago. Anyways I’ve just been testing the voltage readings for both the pre and post cat. With the engine running the pre cat oscillates between 0.1 and 0.8v just over every second or so but the post cat sensor constantly reads about 0.75v which I found odd.
I have a friend who also owns a panda 1.2 8v 2005 with 45k and I plugged in his car (as his idles perfectly) to test the voltages and I found something surprising. His pre cat does roughly the same oscillations as mine but his post cat almost always stays a 0 volts. This is something I can’t understand. Also his throttle position reads at idle 0.0 degrees while mine changes between 0.1 and 0.2 degrees.
I have only done 37,000 miles since the lambda sensors were last changed so they can’t be on their way out again surely. Also recently fuel consumption has increased by a fair amount, so I’m stumped as to what the problem is.
Is it the lambda sensors again, or the throttle body or something else I have missed? All suggestions welcome. Many thanks.
