Has anyone done it yet and if not why not? that is an Abarth 500 ss engine and box into a Panda 100HP transplant.
Not true. The A500 is the 5 speed (C510) unit. The 6 speed (M20/32) units used in other cars is the one you mean.Is it true that the A500 gearbox is the same unit that is in the Astra VXR?
Thanks Lewey, its good to know that someone has done it, or at least some of it - what went wrong for you to decide that you don't like modern cars?Not true. The A500 is the 5 speed (C510) unit. The 6 speed (M20/32) units used in other cars is the one you mean.
The A500 engine and box will go straight in. You would need 500 1.4, 95HP diesel or Abarth hubs and Abarth driveshafts. I test fitted it all into my Panda 100HP last year and bought all the A500 suspension parts, etc. to make it effectively a 500 Abarth with a Panda shell. Then I decided I didn't like modern cars.
https://www.fiatforum.com/panda/253497-1368-16v-fire-turbo-fast-road-panda.html
All the answers are in there. Anything else you need to know I can answer too, but I don't have the time or inclination to type out the specifics of the electronics side of things unless you have it all on your workbench and come unstuck.
That is an expansive question. In the thread I did ramble on quite a lot about how I felt and gave reasons. Basically modern cars are boring and expensive if not wholly suitable for 99.5% of the population.Thanks Lewey, its good to know that someone has done it, or at least some of it - what went wrong for you to decide that you don't like modern cars?
Ok Lewey, I've read that thread and it hasn't put me off yet.
How far on are you with the project now? Dare I ask.
Is the M20/32 the standard 6 spd from the 100hp if so what did they run in the Trofeo A500 car with 180hp?
