General Airbag cover
duxster
Hi
I have a rattle behind the passenger airbag cover. Can anyone advise how the cover comes off?
Robert
Thanks for help. Removed the glove box and had a look at the airbag fixings and all looked fine. Will have to remove it again when I have someone to sit in the passenger seat while I drive and get them to try and locate it.
Cheers.
Rob.
PS: If all else fails and I will try Herts idea :)
Actually though, Dan Friel's answer shouldn't be overlooked. My 4x4 often sounds like something's rattling on the passenger side of the dash, but it is actuallly from the steering column stalks. Just very lightly resting a finger from each hand on the ends of each stalk does indeed stop the sound. Must be something weird about the 'acoustics' of the Panda that this noise sounds like its from the other side of the car.
Thanks but it is the passenger airbag area. If the rattle starts and you push on the cover it stops.
Rob
Hi
Already throught about wedging something in but thought if I could get the cover off I could either sort it out or sandwitch a thin piece of sponge when I put it back.
Rob
Hi
As already mentioned I have already had the glove box out and checked all fixings and nothing is loose. It is the cover that's rattling as it stops when you press on it. The problem is the gap around the edge to very narrow so don't want to stick anything in it if its just a case of popping it off and sorting it out properly.
Rob
