General New mandatory MOT test items from 2012
Thunderbug
Established member
North Hampshire
A few changes to the MOT via the AA website:
http://www.theaa.com/motoring_advice/car-servicing-repair/mot-changes-2012.html
If you've been happily ignoring a warning light because it's not checked in the MOT you could be facing an MOT failure and an expensive repair bill in 2012 because of changes to the test.
The Department for Transport is adding a number of new mandatory test items to the annual MOT from 1 January 2012 to comply with a revised European testing directive.
The aim of the revised directive (2009/40/EC) is to harmonise minimum test requirements across Europe and make sure the test reflects the electrical/electronic complexity of modern car safety features.
VOSA, the government agency responsible for the MOT, has indicated that 'failures' relating to the new test items will be treated as 'advisories' in the first three months. This means that if you have any of the following problems with your car you've got until the first MOT renewal date after 1 April 2012 to get it fixed.
The main changes from 2012
Electronic parking brake
Electronic parking brake controls are now included and must be present and not inappropriately repaired or modified - repair obviously likely to adversely affect the roadworthiness of the vehicle or modification that has seriously weakened the component.
(The 'inappropriately repaired or modified' check is to be applied to a wide range of systems and components throughout the vehicle.)
The car will fail if an Electronic Parking Brake warning lamp is illuminated to indicate a malfunction.
Electronic Stability Control
Checks of antilock brakes will be extended to include Electronic Stability Control if fitted. The tester will check for the presence and correct operation of the ESC malfunction warning light together with looking for obviously missing, excessively damaged or inappropriately repaired or modified components and electrical wiring, as well as an ESC switch missing, insecure or faulty.
Warning lights
As well as electronic parking brake and electronic stability control warning lights (where fitted) the MOT test will also include checks for the correct function of the following, where fitted;
  • Headlight main beam warning light
  • Electronic power steering warning light
  • Brake fluid level warning light
  • Tyre pressure monitoring system warning light
  • Air bag warning light
  • Seat belt pre-tensioner warning light
Steering & suspension
The new test includes a check on the presence and correct function of the steering lock where fitted as standard.
Missing, or split/damaged dust covers on steering and suspension ball-joints will result in failure if they will allow dirt to enter the joint.
Power steering fluid level must be above the minimum level indicated on the reservoir.
Lighting
Products on the lens or light source that obviously reduce the light's intensity or change its colour will become a reason for failure – applies to front/rear position lamps, registration plate lamps, stop lamps, rear fog and direction indicators,
Headlight requirements are updated to take account of the particular characteristics of High Intensity Discharge (HID) lamps.
HID headlights can cause dazzle if they are dirty or aimed too high so car manufacturers must fit headlamp cleaning and levelling systems. A car will fail if a mandatory headlamp cleaning or levelling system is missing, doesn't work or is obviously defective.
Vehicles fitted with aftermarket HID systems must also be fitted with properly working washer and levelling systems.
If a headlamp bulb is not seated correctly the resulting beam pattern will be indistinct and this will result in a test fail.
Electrical wiring and battery
An insecure battery will be a reason for failure as will a battery that is leaking electrolyte.
Visible wiring that is insecure, inadequately supported or likely to cause a short will also result in a failure as will wires bared by damaged insulation.
Trailer/caravan electrical socket
There will be a basic security/damage check of 7-pin sockets,
13-pin sockets will be subject to a full electrical connectivity check and incorrectly connected or inoperative circuits will result in failure.
Tyres
Tyre pressure monitoring systems fitted to vehicles first registered after 1 January 2012 must be working correctly and not indicating a malfunction.
Supplementary restraints
The vehicle will fail the test if any airbag fitted as original equipment is obviously missing or defective.
A seatbelt pre-tensioner fitted as original equipment but missing or that has obviously deployed will be a reason for failure.
Seatbelt load limiters that are missing where fitted as standard or folding webbing type limiters that have obviously deployed are also reasons for failure.
The vehicle will also fail if an SRS malfunction light is missing, not working or indicating a fault.
Speedometer
The car will fail if a speedometer is not fitted, is incomplete, inoperative, has a dial glass broken/missing or cannot be illuminated.
Seats
It must be possible to secure the driver's seat fore and aft adjustment mechanism in two or three different positions. On electric seats the motors must move the seat fore and aft.
Doors
A rear door that cannot be opened from the outside using the relevant control is a new reason for failure.
Doors must be easy to open and close – hinges, catches and pillars will be inspected.
Towbars
Inappropriate repair or modification to the towbar assembly will be a reason for failure if judged likely to affect the roadworthiness of the vehicle/trailer.
Exhaust
A catalytic convertor fitted as original equipment but missing will be a reason for failure.
Fuel system
Damaged or chafed fuel pipes will result in failure.
I'm sure you'll find that with the hid headlights the car has to have (auto levelling) not just the manual button or thumwheel that you get on the car. Which is even worse. Ther are companies that produce such items but it makes these cheap hid kits not so cheap. which tbh is a good thing cos some of them are just slapped in the car and they dont give a damn how they effect on comming traffic.
So much so the sale of anti dazzle night driving glasses has tripled this winter and we seem to think this could be the reason.
a lot of that is taken from the vosa press release from March 2011, a lot of it never got into the new mot in the end, if your hids have the right beam pattern you dont need levellers or washers if they are not fitted you wont fail.
more upto date link http://www.motinfo.gov.uk/htdocs/m4i00000001.htm
note Issue Date 01 January 2012
Was there anything to suggest who will pay for these tests? Us with an increase in the MOT test fee no doubt!
I guess we'll all have to pay for the HIDS, ESC,(and a load of other friggin acronyms), trailer sockets and tyre pressure monitors to be checked even though we haven't got them!
Great eh?
OOH, that's good, I need to start stocking those anti dazzle specs then!! (y)
Correct.
Very poor of the AA to have posted very out of date info. All the forums are now full of people quoting the duff info from the AA too...!
The only relevant change is that if your car has self-levelling (which can be headlights or suspension) and/or washers then those systems now need to work.
Self-levelling headlights are easy to see if they work, so easy to spot if they don't. However, self-levelling suspension can't be tested because most don't level until the car is moving and the test is static. So the testers have to assume they work unless they have clearly failed.
Doors
That'll please Grande Punto owners...
Great eh?
How you come up with that? MOT costs are still the same ;)
Just remove the bulbs from the warning lights that are present. I bet they don't plug in to test...
The warning lights need to follow the correct sequence.
An airbag light that doesn't come on at all will be a failure, just like it has been with ABS for years.
Most of that looks like good sense to me, The headlight washers [if they are on the test] will be expensive to sort out when they go wrong! I had a 'D' reg Volvo 340 with headlight wipers, i need new blades, £18 !!!!! EACH !!!!!
The test to the new 13 pin towing electrics will most likely require an expensive box of tricks to test quickly as they have power supply for caravans as well as lights.
Good idea putting air-bag light in the test too.
