Hi all. Nice to find this forum. I just got a Panda from 2004 and got into some trouble. I only got it with one key, normal type, no remote. The car has central locking as all the doors lock at once when using key on door lock, or when locking from inside. On Christmas I found out that some scumbag drilled the lock on the door and now that's broken. He tried to get the cd-player but didn't succeed. Only damage is the lock barrel. Now until I find a complete set to replace (second hand) I am trying to solve this problem by adding a remote locking system. I bought a kit for about 18 euro with 2 remotes and a control unit. I also downloaded the eLearn software and looking at diagrams. I presume I have to connect this kit to the M001M connector for lock/unlock function, to M001H for windows (kit has negative output for windows) and M001P for turn signals to flash. One thing I noticed is that the left window has an automatic function if I keep pressing for some time on the inside window button, for up and down, but on the passenger side this function doesn't work. The window moves as long as I keep my finger on the button. As well it doesn't work at all if I remove the key from the ignition. Will this affect my ability to close the windows via the remote?
And another thing, does my boot have automatic locking? I only open it with the key. Is there a button in the car that is supposed to pop it? Or this was a feature for the original Fiat remote only? What wire do I need to tap for the aftermarket remote kit to pop the booth? I have this option on the new remote. I repeat, I got the car second hand with only one normal key, no remote, but car has central locking on all 4 doors.
Thank you for your patience, and I would very much appreciate if someone could indicate the booth cable and connector, and if you as well could confirm that the connectors I found are the ones that need fiddling. As well I have 2 options on my remote kit, positive and negative trigger, what type does the Panda need?
