Technical Switching the stereo off with the engine
dr6633
Hi' I have a 2011 panda with the Blaupunks cd169mp3 original HU, is there any way to make it switch off with the engine? The cables don't have any other plug for it and I tried to reach an option using the menu (after reading some posts) but no luck there :(
Thanks.
Press the " MENU " button briefly, then use the up or down arrowhead buttons to scroll to the " RADIO OFF " menu item, then use the left or right arrowhead buttons to scroll to " Radio Off: 00 min ". Press the " MENU " button to exit.
Tried that just now but it didn't help. I've tried it even with the engine switch on and even tried to lock the car with the remote thinking the stereo will shut down but nothing...
In the menu there is "Radio off:00" or "Radio off: 0" and I've switched it to the "00" one. is there anything else I can do? thanks again.
Maybe something wrong with your radio.
According to the Radio/CD/mp3 handbook, the options should be " Radio Off: 00 min " or Radio Off: 20 min ". The 00 min option should turn the radio off immediately the ignition is switched off . The 20 min option should switch it off 20 minutes after the ignition has been switched off.
Perhaps there is something wrong, I don't have the "20 min." option :confused:
Thanks.
