This is about mixture of petrol, right?According to the Fiat manufacturer specific code list I have,
P1172 = "Mixture 1 stength (multiplicative)" and/or "Self adaptive parameter TRA".
I believe these relate to LTFT (Long Term Fuel Trim) and STFT (Short Term Fuel Trim)
start with the simple things and try cleaning the throttle body flap (see stilo guides section)
any other issues with the car any issues cold starting cutting out ect?
Hi!
I have this code and problem with a cold starting - any ideas whats wrong?
Does it start then die after a couple of seconds?
Its depends, but mostly yes or it start to gag
if its mainly when cold I would look at replacing the MAP sensor BUT also get the battery tested a weak battery especially during cranking can cause voltage issues which confuses the ECU
