Technical P1172 fault code
Hopefully there's someone on here who can help with this - my LPG experience with Pandas is very limited.
From experience with Land Rovers, this type of problem may well be an LPG-related one, as the LPG kit tries to fool the ECU into believing that it is still running on Petrol by spoofing the readings from various sensors. Have you contacted the LPG installer? It could be a known issue, and an easy fix.
Apologies for not being able to help more, & good luck with fixing it.
Thanks!
By the way its stilo, but I guess it should be the same...
And yes, I was contacting with them in two different places - the answer is that everything is fine with LPG :( Andy Monty - maybe you have a solution? Map sensor?
Spray alcohol around any areas that could be sucking in air. If the engine speed changes you have found an air leak. Its a more sensitive test on carburettor engines but should give some clues.
