lamlash
I'm getting an occasional clunking noise (quite loud) from the brake actuating mechanism on my 2010 Panda Eleganza. It doesn't happen all the time and seems to be triggered by going over a bump. It stops when the brake pedal is pressed and then restarts again when the pedal is released.
The noise seems to be coming from the transverse steel linkage that runs across the inside of the bulkhead. Nothing seems to be loose. Anyone else had this, and is there an easy fix?
