Cookecarey
Member
I have just replaced the original tyres - Conti Eco Contacts, on my MJ at 16,000 miles with winter tyres. Both original Front tyres were scrubbed / and virtually worn out around the inboard edges, the Rear Nearside tyre was similarly worn around the inboard edge.
A laser/camera steering geometry check by my tyre dealer found that there was excessive Front Toe-in both sides, and rectified that, also that there was excessive Toe in and Camber on the Rear Nearside tyre, but was unable to correct that, "Not adjustable". The Rear Offside tyre was, considering my mileage, virtually unworn. He was also unable to adjust the Front Camber. There was no detectable wear of bearings or bushes.
At the end of the check/rectification, it was found that the Front Nearside wheel Camber was outside Fiat tolerances, the rear nearside Toe in and Camber was borderline tolerance. These factors in his view had lead to the uneven tyre wear.
The vehicle is 14 months old, in daily commuting use, and otherwise fine and very economical. Never thrashed, never crashed or bumped and any speed humps negotiated, oh, so carefully!
So, is there a method of adjusting the Front and Rear Camber to return it to the Factory settings? and if so, what is it?
I have read the posts on here from S-X-I and others for 100HP Steering Geometry settings, which are interesting, but does anyone have the correct figures if they differ, for a 60 Reg 1.3 MJ Dynamic?
Grateful for any assistance.
