On my '05 4x4 I've got a bit of gentle rumbling/knocking from the rear when I go over small bumps.
I should say I am not mechanical-minded, okay with polish and t-cut though.
Having a poke around underneath, I can't really find anything worn or loose, however in the middle of the rear coil springs there are some rubber things suspended from cone-shaped extrusions of the underbody. I assume these rubber things are to dampen or soften the springing. However they seem to be a bit loose – one could be pulled down out of its fitting (though it goes back up just as easily).
They seem to possibly bump the side of the coil springs, especially with side-to-side movement on an uneven surface, so I'm wondering if they could be cause of light rumbling/knocking? I imagine the cone-shaped part of the body above could amplify any knocking. I suppose taking them out completely at least prove whether they causing any noise (that would, at the moment, be beyond my abilities).
Anyone able to tell me exactly what these things do and any experience with them rattling or knocking around?
