The only basic difference between synthetic oil and mineral oil, apart from its manufacture and origin, is the molecular and particulate structure of both the lubricants. Synthetic oil being a perfected product, has a very even and uniform structuring of molecules and particulates. On the other hand, mineral oil contains uneven and less uniform molecules. Now, when the car, engine, piston and piston block is new, it is always advisable to use, mineral oil. The uneven molecular structure of mineral oil makes the uneven surfaces of the components and auto parts rub with each other and erode, thus making the surface even and smooth .This is very useful, as the young components of the engine get into shape and adapt to the mechanism. As the engine grows older, the components, get into shape and start running swiftly without any friction. This is where one should start using synthetic oil. This oil basically keeps the engine in shape and helps in increasing the durability of the engine.
There are several other advantages and disadvantages of synthetic oils as well as mineral oils. Going into the details is pretty difficult and also complex. The debate synthetic vs. mineral oil is almost as old as the time since they were found and is getting more and more complex day by day, due to the advancements that are being integrated in lubrication. The conclusion that which oil is better, hence still remains undecided.
