Most likely, they're a direct fit.
All Fiats run 4x98 wheels and they're all front wheel drive, so the offset etc. should be correct as well.
Unless of course it's a GRANDE Punto in which case the wheels are 4x100......
*Sigh*
Leave it to Fiat to enforce their own standard for wheels and then not adhere to it with a single model out of their entire lineup
Well no, it was a joint venture with Vauxhall. Don't make blanket statements and you won't be wrong
Makes sense to use the same parts as Vauxhall/Opel to save costs.Still doesn't make any sense.
Yes, or a Scudo or any other van type Fiat.Or a five stud Croma.
Forgot about the commercials.
I hear you can get the wheels to fit on a 500 with spigot rings and wobbly bolts thoughFiat G.91 is different too.
All Punto stuff will fit, except for Grande Punto stuff
And Evo
I'm pretty sure the Evo wheels are 4*98
