Hello there - I'm on my second 100HP and inevitably, after bouncing around Kent's shocking roads tonight, have turned to wondering about suspension mods, mostly to make the ride a little more comfortable (or to keep it on the ground at least some of the time ).
Appreciate this is well-worn territory, but - would it be completely daft to try fitting some 1.2 (or diesel) standard springs/dampers? I realise the ride height will increase. But I've never found standard Pandas particularly wanting in the ride/handling department - and the weight can't be much different?
Just a thought...
Otherwise, is the best bet to change dampers, or springs? If the former, presumably Konis; if the latter, I guess it would be Eibachs (but I don't want to go any lower...)
Sorry if this induces groans - I did do a search but not sure what the consensus was....!
Nick H
Tonbridge, Kent
'07 Panda 100HP (Electroclash)
'55 Stilo Prestigio (1 of 27!)
'X' Brava HSX
Just a thought...
Nick H
Tonbridge, Kent
'X' Brava HSX
