MEP is right, it is soldered to the PCB that the dials sit on. You could remove the dial cluster from the dashboard, seperate the housing, de-solder the buzzer and put back together. I found it easier to chop the buzzer's feet using good wire cutters myself. Completely unrelated reason and for a project mind.
